3 way component build
Hello I'm new to this site and am seeking advice on building a 3 way component system and these are the options i would like to pursue.
Option 1 is i have a focal 5 1/4 2 way component system and would like to ad an 8'' midrange driver to this and was wondering if there is a 3 way crossover I can buy to have the 3 way component setup so I run these speakers off of 1 channel as opposed to adding an amp for the additional 8" midrange driver.
Option 2 would be to buy a new setup if anyone has some creative ideas it would be very helpful and please keep in mind that i don't have $800-$2000 to spend on a component set thanks
Focal has several 3-way sets with passive crossovers of which you can get just the xover alone. Part #XO /165AS3 should cost you bout $70.00 bucks or so from an authorized Focal dealer.....
You could get better sound by running the 8" mids active on their own amplifier channels, and add a digital signal processor to set up the crossovers, time alignment and EQ. CDT makes 2 crossovers that could be used with 8" and 5-1/4" speakers plus a pair of tweeters, but you need to consider more than just the crossover settings. Impedance matching is also important, and mixing and matching speakers with passive crossovers is a poor idea.
So if you can answer this question I would appreciate it.
I have an Xtant 4004a that has 50 watts pet channel in 4 ohm and 100 watts per channel in 2 ohms, so would it be a bad idea to run the 8s on the same channels as the focal components and I would be running those 2 channels in 2 ohm load? If I did this would affect the performance of any said equipment and if needed I could get an equalizer
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
874
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
892
I’m sure they will be a good budget setup. I think they will lack some midbass but door treatment is super important so definitely be sure to do...
Sound deadening and door preparations are key to getting the best results towards more SQ oriented within the vehicle, as well as speaker locations
robinhood81647
robinhood81647
new castle colorado
robinhood81647
    May 18, 2024
    May 18, 2024
