'80 VW Caddy (Rabbit truck) system, E30 dash, suspension...
Keep up the good work! Also, I got the same cup holders. Those have LED's, right?
Thanks. Yep, LED's, blue, going with the blue to match the PDX amps. JL emblem will also be backlit through frosted plexi.
Slow at work today so instead of standing around I knocked this out. Modded a V1 hidden remote display and a Stinger volt gauge.
I put some hours in on the router and this is what I came up with.
I started the metal work on the doors (still much more to do)
I installed six 10/24 rivnuts. The pods/speakers are attached with ss button head allens.
I know thread necroing is usually frowned upon, but since youre still an active member, what happened to the rest of this?
I've done some performance mods and cleaned up the engine bay. As of now the interior is still the same, driving it and enjoying the system. Too busy to work on it between  my 8-5 second job, and customer jobs right now.
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
312
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Then I would get the dual 4 ohm subwoofers and wire it to 1 ohm like in the link below. Those subwoofers are 500 watts rms so running them at 1...
ok i get it dodge ram and full strip inside for second skin . power is run down drivers side and speaker wire is run down passanger side thank you
crnacnac
crnacnac
Pasadena,CA
Jeremy11
saints747
    May 7, 2024
saints747
    May 7, 2024
