Aftermarket head unit and factory amp (Hyundai - Monsoon audio)
  • 2
Lowkey
I have a 2003 Hyundai Santa Fe with Monsoon audio. I installed an aftermarket head unit using the harness specifically for my Santa Fe w/Monsoon audio.
I had to connect the blue wire in the harness to my receiver in order to get audio so I know that Monsoon amp has to be on. Am I running off the Monsoon amps power or the head units? Both?
The blue wire only tells the amp to turn on. Amplifier power comes directly off the battery.
I understand, I only mentioned the blue wire because it proves the factory amp has to be on in order to get audio. So both the head unit amp and factory amp are on. So my question is which one is powering the speakers? Also what are the negatives to running it this way? etc
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
664
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
774
Lowkey
Lowkey
Lincoln, Nebraska
Lowkey
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
