Aftermarket radio help
  • 1
Zombotomy
Aftermarket radio kit?
Hello. I have a 2014 Lancer ES without Rockford fosgate. My current radio is the stock double din. I saw a radio on Amazon I want it's a double din touch screen and says it will work with my steering wheel controls. This is it
Putars HD 7" Double 2DIN Car MP3 MP4 Player TFT Touch Screen Car Kit Bluetooth FM Radio USB/SD Aux Input Color screen Car Stereo Player with Remote Control https://www.amazon.ca/dp/B01MDTPK45/ref=cm_sw_r_sms_apa_i_K90cBbYJ65STG
Will it work? Do I need to get a different connector harness and install kit or will it mount in? If I do need a kit can anyone link a cheap one? I am in Ontario Canada
Thanks
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
664
Yellow wire is generally memory/Access(Constant). and Red wire is generally supply that works off ignition/on/off
5
You cant go wrong by adding anything to improve sound quality
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
Zombotomy
Zombotomy
Toronto canada
Zombotomy
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
