Blow through!!!!!!!!!! 2 15's 8000 watts
burzendowski
CA.COM
Starting my newest build and my last.........
list of equipment
2 Treo ssx 15" hybrids
1 8000 watt prototype amp
3-5 treo ssx 100.b batterys
ohio alternator 300a
90 foot of monster 1/0
1 treo ssx 4ch amp
2 sets of treo te coaxials
box is made out of 1" mdf with zero 90 degree angles . all corners are 45's
It should be very impressive. the subs were custom made to suit my build. they have a better and longer coil than stock ssx plus better spiders and double leads as well as a spacer between the basket and motors. these are 3" ssx 15's not 4" coils. My buddy holds the loudest recorded score in midwestspl with subs similar to these, he used 3 of them.
the amp does 7400 at 11.9 at 1 ohm ill be running at 2 ohm daily and .5 for comps.
i also purchased a python 5902 alarm today to keep tabs on my ride.
more pics soon to come.
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
I mixed a trap beat and that christmas song 'silent night' together, then screwed it, bass boosted it, and added a non-stop 25hz note, then put in...
57
5K
been like 20 years since i did just that. 2 l7 15s, 1000watt soundstream usa made amp, 12cu tuned at 34, iirc, that 2 separate vented to the...
5
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
burzendowski
burzendowski
CA.COM
burzendowski
