Ford ranger extended cab semi-wall build
so i threw in my box, and amp. So far I have no idea how to set my gain to about 60% with bass boost off and my hu sub control at -1. I feel like my subs can handle more but the dmm method is iffy. I dont know where to put the volt meter to read how much power I am getting. On a side note i picked up an old rockford 4600x series one for my stock speaker locations so that all my speakers are on amps.
Also that amp pulls a stupid ammount of power. I was dropping to the mid twelves at full tilt with my stock alt and battery bank. I am currious how big of a difference a 250 amp alt will do with a 2/0 ga wire to complete the big three.
Okay update. I am moving the infinity 5x7's to the rear, adding alpine type s 6.5 components to the door along with a pair of r's in the kick. Picked up another alpine 3527 for the stock speaker locations, parted out my l'7s and am buying 4 10" pierce audio wmds. The kenwood hu is going to be coming soon along with the ho alternator. Also I am eventually going to strap on a second md3d
my buddy has an x-cab ranger and put a semi sucky box in it for his Solo X 18 dual 1 - here are a few pix.. I designed the box but the construction was done by him, with pieces and parts it looks like lol... i think its just thrown in for a pic but another Kicker semi for ya. He had the wrong bolts/screws so he decided to use the metal plate behind the top piece of wood for some reason, so it is sealed up there but its stupid. I am going to build a new one for him!
611
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
bunkrd you
bunkrd you
papillion, ne
2022coloradoboi
    May 18, 2024
    May 16, 2024
