inverted sub magnet
Actually, just a regular magnet can screw up a few devices, for instance the tire pressure monitor system in my Jeep. The driver information center says, "please remove magnet from spare" //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif. Usually you should be alright.
It's no different inverted than it is mounted normally. The magnetic field is not affected in any way. The only difference is that you can see the magnet. The wood of the enclosure doesn't do anything to dampen the mag field or contain it.
x2. Magnetic field isn't large enough
Looks like it gets down pretty good. Nothing better than being happy with the work put in. I always like to give a little space between the amp...
16
3K
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
459
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
488
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
595
dannyz122001
dannyz122001
Baton Rouge,LA
dannyz122001
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
