is a low pass filter slope on amp the same slope as subsonic filter ?
papiboul
if my amp is 24db/octave of low pass filter is my ssf slope 24db/octave also? because my subs half 12db/octave rolloff. so shouldnt the ssf slope be 12db/octave?
or some amps have different both the slope of low pass filter and ssf? and some have the same? or its always the same?
sorry i misread teh question completely. But yeah, often times amps have a higher slope on the SSF than they do on the high/low pass filters.
I would say that it would be likely, but not always the case.
So my answer to your question is "most likely, but it depends on the filters used in the amplifier/crossover."
For example:
My JL 1000v2/1 has a low frequency filter slope of 24db, but the low pass slope is selectable between 12db and 24db.
However my Audio Control DQXS has a 24db slope on both the low frequency and low pass filters.
I would think that most low frequency filters are a 24db slope on possibly all but the cheapest amps due to the nature of what is needed in a low frequency filter.
What amp are you talking about?
468
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
629
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
papiboul
papiboul
da hood
t1n0m3n
    May 22, 2024
    May 22, 2024
