Jimmaaay 10+ year member
Greek Man
Ok I just ordered two 2 ohm dual voice coil woofers and I was wondering to wire then to 2 ohms is this how I should do it. Wire the voice coils in parallel (negative to negative, positive to positive) on both subs. Then wire the positive of sub one to the + on the amp and the negative of the sub two to the negative on the amp? Oh by the way the amp is a mono block amp. Just wanted to to see if this was correct to wire these at 2 ohms.
Thanks, James
Thanks, James
