mtx thunder8000
  • 2
ive heard the 6000 and they hit pretty hard so i would have to think that the 8000 would too. they also dont have too bad of a sq if you wanted to know that.
The 8000's will hit nice, but you need alot more power than the 6000's. The 6000's have a higher sensitivity than the 8000's. Then look at 250-500 watts RMS to the 8000's 500-1000 watts RMS. I have a 6000 10" and I am sending over 280 watts to it and its in a .65 cf box/sealed, sound is excelent. Price can be another pivot point, the 8000's cost more, black and white and to the point. If you have enough wattage and want to spend the extra buck get the 8's, but if the budget is tight get the 6's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Good luck
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
784
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
esco
kuntry boi
esco
tampa, FL
Matt
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
