PLEASE HELP!!!
gschobes19
5
NY
I have just recently purchased 3 12in Audiobahn ALUM12X (6 ohm DVC)subwoofers along with the Audiobahn A2300HCX 2400 watts( in 1 ohm bridged) 2-channel amplifier. I am new with car audio and this is my first system.. how would I hook up my subs so that I could get the most out of my amp? I know that with the 6 ohm DVC I can choose either 3ohm or 12 ohm but with 3 subs how would i connect that to my 2 channel amp? Wire the subs in parallel or in a series? Any advice would help, Thanks.
hey greg,i thought you said you had a wall of L7's in a buick regal.you must know alot about car stereo's if you say my 4 15's won't hit 160.i smell something fishy
quote:
If your amp can handle the 1ohm mono load. Then parallel the coils of each sub, then parallel all of the subs to the amp. BLING BLING 1ohm mono load.
[ 01-07-2002: Message edited by: ramos ]
thats kid with the L7s is my brother, he was just on my account, back from college with nuthin to do i guess.. he does have his car sponsered by Custom Radio so i guess u can deush that fishy smell
try ramos' method first.... just make sure your electrical system is up to pushing that much wattage at that low of a resistance... just keep an eye on your voltmeter, and you should rock out...
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
967
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
gschobes19
gschobes19
NY
MxRacerCam
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
