my aftermarket system
  • 4
flava30
NYC
Hi All,
My aftermarket system just starting increasing in volume as I accelerate and then go back to where it was when not accelerating. It's not very noticeable, but I notice it. Any ideas? I had the system for several years already with no issues. Any thoughts would be appreciated. Thanks.
what car do you drive?
This must be some sort of feature that combats road and engine noise and it needs to be turned off.
Big 3 powering, JVC KW-NX7000, (1) Rockford Fosgate Power T1500-1bd, (1) Rockford Fosgate Power T400-4, (4) 6.5" beyma speakers, (1) 12" Kicker Sub, (1) kicker KX3 crossover, (1) capacitor. Like I said, never has this problem since about 3-4 years with this system.
I'd expect head unit failing. That sounds very unusual and that line of RF amps are quite solid and realiable. From my experience after about 2 years head units start to fail these days so I'd look to try to swap that out first.
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
i have no experience with component speakers. Maybe someone else can help in this area.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
690
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
850
flava30
flava30
NYC
hispls
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
