No sound on subwoofers
Did you set up the receiver so it knows you have a subwoofer? That's done in the speaker set up menu. All the other speakers should be connected to the receiver and set for small. There is a bass level control there. The main volume and bass level on the subwoofer also control how loud the sub will play. The listening mode on the sub may affect the sound too.
Lucky Patcherhttps://inro.in/lucky-patcher/ 9Apps VidMate
ok, so its all installed with the subwoofer not playing.  Few things to check here mate;
  • check amplifier wiring, from battery, ground, remote wire
  • check if the RCA is plugged to the amplifier;
  • check if the amplifier is being switched on when your head unit is turned on;
  • use a multimeter to check subwoofer box connection.
  • if you don't have one, open the subwoofer to check it the speaker terminals are secure and connected
  • use the multimeter to check your subwoofer resistance ( hope its not a fried voice coil)
  • check amplifier is turning on, if not then check power, ground / rca connections;
  • Finally if all seems to be connect on the trunk area, then you may have to gain access to the rear of the head unit to check all connections;
  • check if the battery positive fuse / circuit breaker is not switched off or the fuse is blown
  • check your ground from battery to the amplifier to the vehicle chassis.
  • if all works then also check your RCA resistance, and speaker wire to the subwoofer as well.
  • check remote wire that turns the amp on, could be broken or touching ground or just spliced during install so no signal is going to your subwoofer amp.
Hope this helps you out mate!
I have had this is issue in the past So I tried turning my my gain on the amp and the bass rummbled once more Best of luck
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
918
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
910
Daniel Rodriguez
Daniel Rodriguez
Cruzie Skillz
    May 18, 2024
    May 18, 2024
