please help, this is getting annoying
the wire is charred black right around the connection on the fuse holder and its starting to melt. I put the stock wire back in for now and disconnected the wire i put in. Im at a loss
pics would really help. I 2nd the idea that something is getting hot that is near the fuse holder....is it the same kind of fuse holder as the others that melted?
no, i bought a new holder. The ones before were mini anl holders from knukonceptz, this newer one is an anl db link holder. It has been fine for the last 3 months or so.
No i just put a new battery in and it had a lot of trouble cranking over. Now im not sure if its the alternator or starter.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
espguitarist91
yep
espguitarist91
bloomingdale IL
espguitarist91
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
