RCA interference?
  • 2
Dirtrider4eva
√\_The CaUsE__
today after some driving, i noticed my front left speaker/tweeter was not working, and when i turned subwoofer off on my hu, it still played. well i turned the car off, went to the amps, and whenever the rcas to the speaker amp touched the amps rca terminals, the sub "thumped" a little..
i was confused, so i went to HU, checked all rcas, un plugged, re plugged, and re connected them, turned car on, and everything was fine.
anyone know why this would happen though? the two rca cables are run on different paths.
hard to understand what you are asking but if you unplugged and plugged back in the RCA's while the stereo was running you could easily have damaged something - don't do that. Doesn't matter which way you run the cables for this problem, they are "attached" to the same headunit on one side and the same amp on the other.
this i know. never would "hot swap"
i found the issue.
apparently FL rca to speaker amp doesnt like to cling on extremely tight. adjust the fins, and not it does. im assuming the HU was re routing the voltage to sub, although the rca was grounded, the signal wasnt getting passed.
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
No make or model number on it? Do you have an exact picture of the rear and all its glory?
661
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
658
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
579
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
752
Dirtrider4eva
√\_The CaUsE__
Dirtrider4eva
Milwaukee, WI
Dirtrider4eva
    May 16, 2024
    May 16, 2024
