Renovation of the Silverado! 4 15" TREO SSX...teardown!
kylediablo
17 & certified
well everyone at some point gets bored with their build after awhile. im going deaf and im used to my truck. just doesnt give me the wow factor anymore. Even though alot of people think im dumb for messin with a perfectly good system, for 2011 im rebuilding.
LINK TO ORIGINAL BUILD LOG
http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/458763-4-15s-walled-99-silverado-z2lv-my-daily-driver-old-build-log.html
July 2009
-wall build 14cubes tunes at 30. 2 layers 1.5" thick with a layer of 2x4's on back and 1.5" steel tubing inside.
August 2009-December 2009
- (4) 15" Fi/crossfire hybrids.
- DD z2lv
- (2) stinger spv1700
BEST SCORE.... 151.3 on dash @ 41hz
April 2009-present
- (4) 15" Treo SSX
- Stetsom 14k2d modded
- 5 cd tech 104ah in bed
- 5runs 1/0 (added in november)
- 4 tejcurrent 230amp alts (added in November)
Best score..... 155.9 in kick and 155.1 on dash @ 39hz
my goal for 2011 (will be done before spring break in PCB) will be hopefully to be 158 range for usaci.
- box will have dual tunings with a removable insert. 33hz with insert for demo/daily...38-45hz for comp.
-box will also prolly be a little bigger to acommodate larger port area.
-several ground runs and maybe new batteries because i am still getting a voltage drop that i dont want.
but for now im just gonna throw alot of test boxes in that i have been wanting to experiment with haha.
2010 pics
tearout pics.... when the termlab worked i got 145.3 outta that assassin 8 @58hz
for sure lol it was tuned at like 55z. i changed it up a lil bit and threw both 8's in a temporary box and i almost wish i could take it to a show like this haha loud as hell......
and i am wanting to get started soon i just need to get motavation. its work on this or work on the yukon, but i need more cash for that thing lol
i have almost got in like 5 wrecks already. everytime i drive and night and have to turn i roll the windows down cuz i cant see they are all 2.5% lol
Here is pics of my Tejcurrent quad alt and bracket install in my 99 silverado. install took around 3-4 hours total. instructions were very detailed though, with very good pictures to help. thanks Troy!
pics of the alts and all hardware out of the box!
old mechman alt
the ECM has to be moved forward to allow clearance. to do so take the battery tray out and the ecm will unbolt. bolt it back in forward so that the second hole is now in the first position
make sure you grind off the powdercoating around the mounting bolts before you install or you wont get a good ground connection.
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
643
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
7K
I have a nissan and i put mine on a switch that has my aftermarket reverse lights.worse case scenerio,u can do that.i just have to flip the toggle...
This is not subjective. Matching the resistance of a given speaker to the amplifier in use is part and parcel of the function of the system. If...
18
kylediablo
17 & certified
kylediablo
chatham, il.
Annnarbor84
    Jun 1, 2024
    May 31, 2024
