running amp from cigarette lighter
I just read through it all... Wow. Did the owner of the car know about the car fire waiting to happen? Glad to see you did it right. In my opinion if it can be returned to stock OEM without having to order new parts, it's not modification. At least not major modification.
---------- Post added at 08:08 PM ---------- Previous post was at 08:08 PM ----------
Beef up the electrical to the cigarette lighter. Make it ******* 1/0 awg if you can. Nobody will ever see that **** under the panels
This x6372905040401
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
519
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
soundstream16
soundstream16
Huntington Woods, MI
tryan77
audiobaun
    May 19, 2024
    May 19, 2024
