But it wont be a small ported. I have space to put up to 5cu ft enclosure. depth of box doesnt matter as long as you have proper volume does it?Sealed at MAX dimension will probably SOUND louder than Small ported
Ugly sub, completely out of my price range.1 cube box with an SPG555. do it.
From the dims you gave earlier, i got 3.8 cubes, unless i missed somethingBut it wont be a small ported. I have space to put up to 5cu ft enclosure. depth of box doesnt matter as long as you have proper volume does it?
I always forget about the ssa's as I have never heard one personally. I would like to try a gcon or icon one of these daysSSA Gcon maybe. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Last I checked, the Gcon 12 is $199. The Dcon 12 ported would be an excellent choice, if you can squeeze a small ported box.Gcon out of my price range though. Any comments on dcon series?
You said budget of 200... they can be found for about 50 to 100 more, not sure what you mean by ugly sub?But it wont be a small ported. I have space to put up to 5cu ft enclosure. depth of box doesnt matter as long as you have proper volume does it?
---------- Post added at 02:35 PM ---------- Previous post was at 02:35 PM ----------
a Diamond D612 D2.Needed: Advice on either 2 -8" or 1 - 12" sub to match a Eb nine.2x
Amplifier Specifications
200W x 2 @ 4 Ohm
300W x 2 @ 2 Ohm
600W x 1 @ 4 Ohm
Detailed Amplifier Specifications
Signal to Noise Ratio >95dBA
Variable Input Sensitivity 150mV - 7.0V
Remote Variable Input Sensitivity No
Variable Low Pass X-Over 40-240Hz @ 12dB/Octave
Variable High Pass X-Over 40-240Hz @ 12dB/octave
Current & Thermal Protection Yes
Remote Gain Control No
Variable Phase Control No
Master / Slave Option No
Efficiency 67%
Variable SubSonic Filter N/A
Fuse(s) 3 x 30A
Max Current Draw 85 Amps
Damping Factor 300
Budget $200.
Enclosure will be custom made to match sub(s) purchased.
This will be placed in a Yukon. Third row seats can not be removed for more space since my son takes several other friends and family to school with him. So this limits depth of enclosure to about 10 inches.
What will match that amp and give the loudest volume for the budget?
