Type R setup, which one?
AllenH427
So I'm pretty sure I'm going to be getting 2 12" Type-Rs. I have all Alpine speakers, so I'm going to get Alpine subs. Anyways, I don't know which amp to get. I'll be getting the 2 ohm, or 4 ohm version depending on the amp. The 2 ohm subs get 2 hz lower than the 4 ohm subs, so that's a plus.
http://www.audioque.com/aq/AQamps.htm
The 1200D with 2 4ohm subs ran down to 1 ohm
http://www.woofersetc.com/p7502/BXI-1210D--Hifonics-1200W-1-Channel-Mono-Block-Amplifier.htm
1210D with 2 4 ohm subs ran down to 1 ohm
http://www.woofersetc.com/p7501/BXI-1610D--Hifonics-1600W-1-Channel-Mono-Block-Amplifier.htm
1610D with 2 2ohm subs ran to 2 ohms
Personally, I've heard good things about Audioque, but I don't know how trustworthy buying from their site is. I've already had stuff ordered from woofersetc, so I'm comfortable with them. Also, the Hifonics 1610D give's me some breathing room if I ever wanted to run down to 1 ohm. The only problem with Hifonics is that I've read they shut off at 1 ohm, but obviously that won't be an issue with the 1610D since I'll run it at 2 ohms.
Or better, if you can find me a PDX 1.1000/MRP-M1000 in that price range, I'd praise you.
Audioque has some of the best customer service...shouldn't hesitate to buy from there. I have two AQ 1200D's great amps should push the arghhhs well.
Audioque is an excellent company. My dealings with them have all gone extremely well and the customer service is fantastic. I'd go with the AQ over the HiFonics any day.
456
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
694
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
813
If you want something weather resistant, get a marine amplifier.
AllenH427
AllenH427
Cincy Ohio
AllenH427
    Jun 1, 2024
    May 31, 2024
