What should I do? Help please.
Ok it looks like I am going to have to file with the BBB about this. I am not taking a crappy w0, he says "JL is the best, IDQ is not popular for a reason" I know IDQ is a great company and the 10v2 is a great sub. I am not taking this crap.
If he is insistant on giving you JL audio tell him to give you 2 13w7's then, tell him to make this bad experiance somewhat bearable and then sell them biches on here or e-gay and buy whatever you want...
Tell him w0's are not adaquate compensation for this unfortunate situation that he put himself into and you are not going to be bought off cheap for their shotty work...
How about some pics of the Sub, The damaged area. Show some proof that the install was the cause of the failure,
Were the subs new?
Is the box to spec?
Can you show that they touch?
He himself admitted that the sub hit the panel and that is what most likely caused it to fail. I dont have pics because the subs are hidden behind my quarter panels and I cannot see them.
the IDqs are very popular, plenty of people use them. the shop owners just a moron.
make him get you something of comparable value, at a minimum i'd say a W3 if you wer estuck with JL, but hold out for a W6
Post some pics of the install please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And print out the MSRP of IDQs, and tell him you want a sub thats comparable a pair of W3 10s or something wouldn't be that bad.
JL isn't a bad brand at all, really nice build quality and Manville is a decent guy.
I'd be willing to bet if you went in there with a few print outs of websites asking a couple of hundred bucks for an IDQ they'll either give you money to order another sub or he'll give you something of equal value of both subs.
I understand him not wanting to give you a pair of subs because they messed up one woofer....i wouldn't either.
If the sub is barely hitting the side panel its not going to cause it to fail also, it might sound like ass but you would be able to tell it was hitting it way before it messed up.
Whats wrong with the sub? If it burnt a coil I'd be willing to say it wasn't because it was hitting the side panel
Both woofers are dead now, I spoke with IDQ and they said it surely sounds like an install problem. They said for one woofer to go out is realistic, but both within 5 minutes sounds like they set something wrong with the gains. Also both of them worked fine before the side panels were put back on. The tech guy at IDQ said DO NOT take the w0's or it will be case closed for accepting this. He said for the shop owner trying to tell you w0>IDQ he is hiding something and wants you to give in to this deal. I am going tomorrow morning, IDQ said to ask for the subs to be pulled and leave the boxes empty. Any tips on what I should say tomorrow?
try to locat manville and let him know how one of his Jl dealers are treating you. is manville on this forum? or is he over at diyma?
Where can I reach him? I'm going to the shop in the morning to get the subs pulled out and figuring out what to do.
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
The CT's are nice, That Sundown is a a frik'n beast!
882
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
730
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
845
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
comp2007
comp2007
Phoenix,AZ
comp2007
