Aftermarket 2013 Acura ILX accessories
  • 1
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
618
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
949
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
706
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
k.norberg97
k.norberg97
Utah
k.norberg97
SlugButter
    May 4, 2024
slater
    May 2, 2024
