los33
Car Audio G
Those 7ks probably do 7k @ 14v so at 16v those amps will reduce in amperage needing less supply..1000x16= 16000 then voltage drops. if you don't have enough constant supply the caps will discharge and become a burden. the batteries will only discharge once the resistance is higher than there ESR. in this situation Id recommend you get some lithium batteries. unless you have a capbank capable of discharging 16K for 2 minutes i wouldn't even bother.
Also he wont be running a burp constantly so the batteries will have recharge time.
Sent from my Z981 using Tapatalk
