whitedragon551 5,000+ posts
Moderator
Ever been hooked up to an o scope?i push my bxi2010d at 2ohms at 14.5 volts and i never have cliping problems
garuntee i could trade u cash for that 3k //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifthe MM series amps are worth every penny. i wouldn't trade my MM3000.1 for anything.
whitedragon551 stop spreading bs claims... keep your un-backed, untrue opinions to yourself.
must be an 09'er thang. not but a month ago he posted a thread VERY similar to this one... when you see that his case falls apart even more //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifthe MM series amps are worth every penny. i wouldn't trade my MM3000.1 for anything.
Not one person has posted any info proving that the new Maxxonics made MM amps are worth a dime. They have however in fact posted info proving that the Maxxonics brand Hifonics does produce garbage clipped power.the MM series amps are worth every penny. i wouldn't trade my MM3000.1 for anything.
PWNEDi see your a fan of dc
ask rusty why he uses these so-called "garbage" hifonics amps.
THE END //content.invisioncic.com/y282845/emoticons/tomatoface.gif.6507032fedd1868ec0a6a447bb29a18a.gifi see your a fan of dc
This guy has to be the biggest hater online. I think he just jumps on threads to argue on the internet,don't feed the troll!Regardless of actual fusing on the 1208d and 1608d amps. They still produce shitty clipped power and they are over rated.
I was actually on my way home from college. I will ask Rusty why he uses them. 9 times out of 10 its because Hifonics is cheap.**** u left that biaatch... whitedragon551 speechless
Straight from Car Audio Mag.TEST RESULTSOUTPUT POWER @ 1%THD,
100Hz, 14.4 Volts
Mono @ 4 ohms 1,708 watts
Mono @ 2 ohms 3,062 watts
Mono @ 1 ohm 4,696 watts
100Hz, 12.5 VOLTS
Mono @ 4 ohms 1,237 watts
Mono @ 2 ohms 2,223 watts
Mono @ 1 ohm 3,512 watts
Distortion at rated power,
100Hz, 14.4 volts 0.1% @ any impedance
Input sensitivity 216mV to 9.0 volts
Frequency response (+1dB) 18Hz – 195Hz
S/N ratio (A weighted,
below clipping, min gain) -78.3dBA
Slew rate 2.52V/µS
Damping Factor @ 100Hz, 4 ohms 157.5
Idle current 8.0 amps
Maximum current consumption,
unclipped 465 amps @ 4,696 watts
Efficiency at 1/3 power, lowest impedance 71%
Efficiency at full power,
1% THD, lowest impedance 70%
Crossover slope 24dB/octave
Crossover range, lowpass 15Hz - 250Hz
Low-frequency boost +18.5dB @ 45Hz
Dimensions
28” (711mm)L x 11.2” (285mm)
W x 2.6” (66mm)H
