SOLD WTS: Orion HCCA D2400
  • 1
IshbOO
Technical Specification
* RMS Power Range : 425-1200 Watts
* Number Of Channels: 1
* Maximum Power: 2400 Watts
* Built In Crossovers: Yes
* Channel Separation: Yes
Features
* 2400W Class D Mono Amplifier
* RMS @ 4 Ohm: 1 x 425
* RMS @ 2 Ohm: 1 x 800
* RMS @ 1 Ohm: 1 x 1200
* Variable low-pass 30Hz to 250Hz
* variable high-pass with INTELLi Q 20Hz to 150Hz
* 10dB of boost with INTELLi Q
* Remote gain capable
* Selectable AUX out
* Fuse size: (3) 40 ATC
* Dimentions: 12.6" x 10.2" x 2.4"
* Power Rating: 425 Watts RMS x 1 at 4 ohms
* Signal to Noise Ratio: -57dBA (reference 1 watt into 4 ohms)
* Additional Power Output: 1200 Watts RMS at 1 ohm
* Massive loosely-regulated MOSFET power supply
* IntelliQ Bass Optimization Circuit and Remote Gain Control
* Heavy Gauge Direct-wire High Current Power and Speaker Terminals
* 18dB/octave Low-pass Filter
Pictures will be up soon.
I know these are pretty hard to find now.
Asking 200$ Plus shipping.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
I have created a post with all related information regarding the build under this link: https://www.caraudio.com/threads/2000-camry-build.614208/
50
4K
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
IshbOO
IshbOO
St.Louis, MO
IshbOO
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
