Beginner System Need Help w/AMP&SUBS
Most boxes use 3/4" MDF except for bigger setups where thicker wood is required. And is this a sealed box? Do the subs have their own chamber? And where did you go to pay $500 for it?
Yes its sealed. Customed tuned for I think it was a caprice. Truthfully I would say it was 3/4 ION. I half assed the thickness because it was hard to tell and It was only about an inch or less. I heard sealed is the way to go for 3 10's or its just opinion to go sealed or ported whatever tickles your fancy. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yes its sealed. Customed tuned for I think it was a caprice. Truthfully I would say it was 3/4 ION and its all one space.. I half assed the thickness because it was hard to tell and It was only about an inch or less. I heard sealed is the way to go for 3 10's or its just opinion to go sealed or ported whatever tickles your fancy.
just pm me the links and i'll post them for you.
the math for a common chamber is different. you don't just take the airspace for each and multiply by 3. you multiply by something around 2/3 or 3/5. you'd really want to nail down the exact volume if you want to be precise. otherwise, it was probably for three 10W3.
PM'd the pics. BTW you've been a lot of help. Thanks.
that box is nothing special. probably $40 in materials. terrible jigsaw cuts. i'd want to carpet it as well.
buy whatever 10's you want, they don't certainly don't have to be JL - i expected a custom MDF/fiberglass box made by JL. that is just random.
I was told it was custom made for a car my dad had. Never said specifically for JL I had a guy from a shop look at it and he said JL, Also the middle ring looks messed up but its just a piece of cloth or some material on the edge of it. Thanks though. Last thing is should i match up max rms wattage from the 3 subs to get an amp that is higher than that of the rms?
agreed i see nothing worty of 500 dollars for that box to be honest. unless it came with speakers.
I believe it did. They were taken out. I cant sit here and explain everything it was a gift and was told some info im just telling you guys what i was told regardless if you think its wrong or not. I just needed some help ID'ing some equipment i should get Brand of Subs/Brand of Amp.
503
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
983
16
999
NewbieTB
NewbieTB
Tacoma,Wa
IonRL205
audiobaun
    May 19, 2024
    May 19, 2024
