Low watt amp sounds louder than higher watt amp
TheHoodler
18
Detroit
I have 4 gauge wiring going to a rockford fosgate 500 watt mono amp. I recently bought a JL audio jx1000 watt mono amp. I'm powering a rockford fosgate p3 4 ohm wired to 2 ohms. With the same exact connections, the 500 watt amp sounds about the same as the jl audio if not louder. Checked and quadruple checked all my connections. Does anyone have an answer as to why my p3 isn't jumping out of its box on the jl amp?
1: you dont have enough electrical to feed the jl
2: not a clean enough signal line
3: if its a 500 bdcp then the constant power would be louder than the JX which is not a regulated power supply.
its the prime series amp, got it like 3 years ago. I'm pretty sure the birth sheet said 650 watts. But i also measured the voltages and both amps are getting 14.4
thank you I appreciate it. I just got a sundown x-12 in the mail today so im tryin to figure this out. I'll post my findings tomorrow.
Oh ya?! Love their subs....they can do some damage and then some. I hope you get a custom enclosure for that sub.
558
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
713
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
TheHoodler
TheHoodler
Detroit
Jeffdachef
maylar
    Jun 2, 2024
    Jun 1, 2024
